vcRealProperty
A property that holds a Real value.
Parent: vcProperty
Children: vcDistributionProperty
Referenced by: vcSingleDofLinkJoint.PassiveValueSource
MagnitudeRealRWGets or sets the magnitude of a property's value.
QuantityvcQuantityRWGets or sets the quantity of a property's value.
TypevcPropertyTypeRGets the property type.
UnitvcUnitRGets the unit of a property's value.
ValueRealRWGets or sets the property's value.
waitForobjectReal OR None value,
waitForNotobjectReal OR None value,
Example: Real Property Limits
"""This example shows how to set properties with limits and setting their values"""
import vcCore as vc
comp = vc.getComponent()
real_prop = comp.Properties["Test_Real"]
real_prop.MinValue = 10.0
real_prop.MaxValue = 100.0
real_prop.Value = 50.0
print (real_prop.MinValue, real_prop.MaxValue, real_prop.Value)
#prints 10.0 100.0 50.0
Example: Set Quantity and Unit for Property
""" This example shows how to set the quantity and unit to vcRealProperty. """
import vcCore as vc
prop = comp.Properties["ProcessTime"]
quantity = vc.vcUnitManager.findQuantity("Time")
prop.Quantity = quantity
unit_group = vc.vcUnitManager.findUnitGroup("Time")
unit = next(unit for unit in unit_group.Units if unit.Name == "hours")
prop.Magnitude = unit.Factor
